  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Fuel cut defender is basically a device that sits on the signal from the AFM to the computer and stops the signal from saturating which would cause the boost cut to be hit. Boost cut on most Skylines is about 1.1bar, the fuel cut defender stops it from hitting boost cut, can be good if you have aftermarket turbo's.
I'm ignoring you Ken.
See'ya:burnout:
Natural progression items to mod ?
1. Exhaust, Cat back
2. Intake
3. Boost up (small)
4. Front Mount Intacoorla!
5. Exhaust, Dump and Front, and Cat.
6. Boost up more
At this point you can choose to start blowing intercooler pipes and working your turbo too hard like our buddy Hicks.
Or take the other A/M Turbo Approach, possibly bigger injectors and all the stuf that goes with it... this is when you start spending the BIG $$$ (something I'm not going to do)
-Kym.
Originally posted by Adrian_perth
strich9ine u big dawg
may i ask what mods you done to ur car?
to get that Fast and Furious Style 14.8?
adrian :D
http://www.hyperwa.com/sau/mycar.htm young adrian..
and the 14.8 isn't my fault it's running richer than your mum's pimp!
overfuelling BAD! safc coming soon.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
