  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Fuel cut defender is basically a device that sits on the signal from the AFM to the computer and stops the signal from saturating which would cause the boost cut to be hit. Boost cut on most Skylines is about 1.1bar, the fuel cut defender stops it from hitting boost cut, can be good if you have aftermarket turbo's.
I'm ignoring you Ken.
See'ya:burnout:
Natural progression items to mod ?
1. Exhaust, Cat back
2. Intake
3. Boost up (small)
4. Front Mount Intacoorla!
5. Exhaust, Dump and Front, and Cat.
6. Boost up more
At this point you can choose to start blowing intercooler pipes and working your turbo too hard like our buddy Hicks.
Or take the other A/M Turbo Approach, possibly bigger injectors and all the stuf that goes with it... this is when you start spending the BIG $$$ (something I'm not going to do)
-Kym.
Originally posted by Adrian_perth
strich9ine u big dawg
may i ask what mods you done to ur car?
to get that Fast and Furious Style 14.8?
adrian :D
http://www.hyperwa.com/sau/mycar.htm young adrian..
and the 14.8 isn't my fault it's running richer than your mum's pimp!
overfuelling BAD! safc coming soon.
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
