  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Fuel cut defender is basically a device that sits on the signal from the AFM to the computer and stops the signal from saturating which would cause the boost cut to be hit. Boost cut on most Skylines is about 1.1bar, the fuel cut defender stops it from hitting boost cut, can be good if you have aftermarket turbo's.
I'm ignoring you Ken.
See'ya:burnout:
Natural progression items to mod ?
1. Exhaust, Cat back
2. Intake
3. Boost up (small)
4. Front Mount Intacoorla!
5. Exhaust, Dump and Front, and Cat.
6. Boost up more
At this point you can choose to start blowing intercooler pipes and working your turbo too hard like our buddy Hicks.
Or take the other A/M Turbo Approach, possibly bigger injectors and all the stuf that goes with it... this is when you start spending the BIG $$$ (something I'm not going to do)
-Kym.
Originally posted by Adrian_perth
strich9ine u big dawg
may i ask what mods you done to ur car?
to get that Fast and Furious Style 14.8?
adrian :D
http://www.hyperwa.com/sau/mycar.htm young adrian..
and the 14.8 isn't my fault it's running richer than your mum's pimp!
overfuelling BAD! safc coming soon.
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
