  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
meh my excel am the gay
i tried putting stereo in and cause way the dash sits i now onlty have half a heater.
i hate it. the only diff with it being a LE is it cam with a dashmat standard and standard it has the spoiler and rims. feels a little (don't laugh) gutsier than the others i drove though.
but hopefully at the end of yeah ill have a GSR lancer or a rex
CAM- i wouldnt call 14.1 crappy ;) ill swap cars if u want
Psiker
hope they do put a track near the airport - i may be able to attend some of these runs then - cant be fagged going down to kwinana haha in fact one of my friends has a two storey house and u can see the airplanes land from it so i'll just sit up there with my beer and watch u guys run the mile. We've already got planes and trains around here so a bit of motorsport noise dont bother me!!
yeah im more central kinda near belmont.
Nah i dont have to worry about reducing mileage - odo's stuffed at the moment anyway. Fuel costs are the main issue - then again once i get on a freeway my car is good on fuel its just the stop start it gets hungry in. Most of all after work i really dont fell like a 40min drive either way - long way to go to find out ya car has shameful times!
haha maybe once its been played with a little more - i prefer to be pleasantly surprised that dissappointed. Nah stuff to do then i shall run it - but dont expect to see it down there anytime soon. Plus im a bit worried because the more power u put into it the more things go wrong and its alright for u guys cos u have a better idea how to fix it then i do - im a bit more helpless in that dept.
Most of these guys are helpless in that department including myself, but a Skyline can withstand a decent thrashing and survive.
I can't believe I actually read all of the whore posts since I left, and some of it was actualy interesting, go figure.
See'ya:burnout:
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
