  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
Your item was processed in the international processing centre (MELBOURNE) at 10:28 on 21 Feb 2003, and has been transferred for delivery processing.
my flywheel is in australia yay
ebc is still 2 weeks away grrrr
payed for it already and now its gonna take a 5 weeks to finally get here
Where the hell did u buy it from
jungles of borneo?
No probs mate
I put the baby on there so the ladies think im married so they dont All bother me :)
ya got to do something with that avatar macka its ruining ya chances haha first thing when i saw it i thought awwww what a cute son haha.
skyzerr haha i dont know probably on the net by now.
