  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Bloody hell , that's the last time I will say it's quiet in here.
Get on to find 6 pages of , animals , sex , animal sex , crap , table crap , sexual predelictions and
..Skyzerr obviously runs a porn site on the side with Nizmo helping. ( boy and I thought she was the quiet one , did I get THAT wrong )
Made interesting reading ( not ) :) and will see what happens tomorrow.
Night peoples
Cheers
( I'm too old for this shit ) quote Lethal Weapon;)
Ken
Night peoples
Cheers
Ken
yes ken its all your fault. lol
i hvae run one before, it was a free site but they closed me down as it was against the isp's regulatons to have one on there server. just done some questionable things while at tafe which lead to seeing lots of sick and perverted stuff. i've just about everything u can think off.
fisted? :lol: no I dont do that to women... maybe you do, not me!
ATM I am one of my mate's house, had another house party! ;) chicks were there but all taken by mate's ohh well but I still managed to have fun with them ;) alwayz :)
they are all crashed on the floor lol! dont know when they will wake up... I never seen soo many beer bottles and bottle caps. hahahha... :)
cheers
Joe
Originally posted by skyzerr33
oh and the sickness wont be so bad tonight
i'm at kylies so no puter
So I hope you don't practise any of that sick stuff on Princess Lea ( misspell intentional .:) )
If you do , can I video , could be worth a fortune, Hehehe
Cheers
Ken
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
