  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
havent really read back! Why was he killing it with wholesome goodness - geez i worked so hard to pull everyone into the gutter and someone just cleans it up when im gone haha.
I'll be right to drive tommorrow Joe - probably advoid drinking a huge amount tonight - its just im not a morning person haha
Originally posted by Pva_Glue
I have a dream that one day this SAU will rise up and live out the true meaning of its creed: "We hold these truths to be self-evident: that all POSTWHORE are created equal."
I have a dream that one day on the red hills of Perth the sons of former WHORES and the sons of former PIMPS will be able to sit down together at a table of POSTWHOREhood.
I have a dream that one day even the state of Western Australia, a desert state, sweltering with the heat of injustice and oppression, will be transformed into an oasis of freedom and justice.
I have a dream that my four POSTWHORES will one day live in a FORUME where they will not be judged by the NUMBER of their POSTCOUNT but by the content of their reply.
I have a dream today.
Joe u get any wierder and no ride in the MKIV for u
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
