  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nice pics man
unfortunatly i couldnt whore earlier i had to go straight to work
was a good crooz. i was in hicks car when the bingle happened. heard a big squeal, smash, then another smash as we were hit. scary stuff :D
i hope sneeza is ok. i feel bad for her.
but on the plus side i got to drive her car the rest of the way to the dam!
i was stocked at that
but yeah. i hope all partys get there cars fixed asap and can come cruising with us very soon
Psiker
