  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
GTS-T, no he was a student. He had deferred his studies because he had to work to save for uni fees, did not get the appropriate visa, and worked too many hours.
Just pisses me that someone can get sent out of the country for working too much. We have the honour of paying to keep some foreigners in jail for commiting crimes, why not send them home?
They prefer to send home poor students who have to work to pay their fees. Need to think of something else before profanities start appearing on screen.
It's OK, now I am crying again!!!
ok I under stand his situation but law is law...
I am with student visa also with work permit, so I really have to be very careful I dont over work...
there are limitations you can /can not do with student visa, if he had studen visa then he shou've have studied not work!. it's the law...
if he willling to work then should get employed by appropriate employer...
Law is complica but if you are willing to learn it's easy and you know some thing others dont.
It's not fair for me too... my University fee is like $7700 a semester, I work but I still get taxed! and no help from goveernments what so ever, I pay my own medibank private...
it sucks they still charge me tax! :)
anyway me two cenets
I agree he was stupid for not doing it properly, but immigration told him to get out, so he purchased a ticket, gave them all the info, and 2 days later they pulled him off the street and put him in the detention centre.
He agreed to go anyway so why lock him up (at his own expense, $350 per day) and not give him a chance to finalize his affairs here? Immigration may have considered he was at risk of going into hiding, but don't we have a policy of innocent until proven guilty?
And for $350 a day, they should be able to stay at Burswood under armed guard! Or maybe something a bit more...4 star.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
