  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My fav song: Learn to Fly - foo fighters dunno why i love that song just do :P
Yeah i got some African American shit in my car - nothing hardcore my ex used to have the hardcore stuff and all this crap about killing their bitches, doing drugs, and killin some more was absolute crap - im sitting there thinking and this stuff u like to listen too haha major turn off!!
I've got a MOBY album. Definately have to be in the mood for it, it can be quite depressing.
I should really be reviewing EXCEL right now. I got a promotion at work, and I need to know excel inside out. They don't really know that I am pretty much computer illiterate. I never actually told them I am a computer genius...I did tell them I can work a computer, and that I could handle anything they care to give me...
I'm really in the shite. Well, I have until Monday to learn. A sickie would not be a good idea right niow. Can someone tell me if EXCEL is an easy programme? This is comming from someone who can take up to 5 minutes to find the on/off switch on a computer.
Angel excel is not the easiest program but i find throwing yaself in the deep end and learning as you go along probably the best way to do it - that way you learn what you need to know and dont get confused with a book that teaches u mindless crap and things you'll never use.
P.S - the only program where the talking paperclip is actually helpful :P
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
