good to hear - know what its like for the wheels to be out of commission for ages - had that plenty of times with the ZX 3 - 4 weeks at a time no matter what was done they just couldnt get injectors and fuel flow right - even to this day i still dont think its right even with new injectors.
I think plenty more rice shops will pop up too - it'll be like those japanese stuffed toy/pikachu logo'd/ stickers etc shops in perth - firs tthere was one and now theres about 2 of these useless shops in every mall.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah trust me from looking at the line you would swear you had entered an asian country - me and my friends just walked past and went hmmmmmmm - keep walking. Daniel (25GTT) used to work there but since the stabbings he doesnt anymore - even that in itself has to say something.
haha we've basically got one of everything from the Lions den in our house - if my parents ever "crossover" i could start up my own lions den with the ammount of memorobilia in this house!
well from just the study (one very tiny room in the house) i can see a HSV wall calender - HSV briefcase at my feet along with all the bullcrap they put in it - every magazine to do with the cars under the sun - a framed article that Xcelerate did on my parents cars ummm yeah thats just one room we have god knows how many to go - you should see the lounge eeek! What i have to put up with!
There is a brothel in kelmscott called annameikas and its got on the sigh "fitness and massage center" and there is a treadmill in the window. I told my friend and she goes "no thats a fitness and massage place" and I said - yeah but what to they massage...eewwwww I bet seedy bogans go in there
Originally posted by Pva_Glue
no troy, I dont need to go to brothel... my girls come by my place often enough to not to go there...
but I know postwhore paul works right next to the brothel and he loves it ;p I am sure he has account there :(
intereseting seeing you admit to being a virgin
my god niz move out now b4 you catch holden disease
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
