  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahahha.... speaking of dating older people...
My ex was two years older than me :P
and I grew up :P
hahahha :)
One time one 32 yr old lady ask me out for dinner at work, I politely agreed and said it's just friend thing right? :D
then she never talked to me :(
why chicks cant take if guy just wanna be friends..eh? :confused:
Yeah - I have a line at home that work pays for - so I can work from home during the nite if stuff goes wrong. COBOL caused all my problems hahaha I nearly failed it at uni and its still haunting me now at work! hahaha
It sucks how uni only acknowledge the federal holidays.... I used to hate going to uni on monday for the 8.30 lecture hahaha
hahaha I know - it sucks... I don't have to know it but they load COBOL frickin flat files into oracle.... so I just blame all probs on COBOL hahahaha
What is it with COBOL anyway - bloody environment division, procedure division - WHATEVER hahaha It was invented by a women - which explain alot... we're not great coders.
Working from home is ok - I can't just do it when I want - but its better than having to drive to the office at 3am to delete a file hahaha
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
