  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cant seem to get mirc to log on - not sure why cos I used to be on there a few months ago & everything worked ok
Troy - you're number didn't come up on my phone, never does. You must have your phone set to block the number.
Paul - no more faults from the knock sensors but there is still something very wrong. Ken & I tried another ecu & swapping an AFM today, still not sorted. On the way home from his place the idle was high & a bit rough. It is running way rich & now crackles more than usual. Parked the car for an hour or so & restarted & then the idle was way low!!! Really starting to shit me now:(
