  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Still think the popping and crackling on overun plus the fuel smeel is the AFM giving an incorrect signal.
It probably has to die more b4 it codes or the wiring going to it could be at fault.
Cheers
ken
Ken, I didn't see your name on Lauren, free game:p
Micko, Anything which will allow you to view the main sensors has got to be of benefit, sometimes a worn wire will cause noise on the signal which will cause this sort of strange behaviour.
See'ya:burnout:
Crackling - I'll give ya crackling...
When I got home I was listening to the idle whilst cooling down the turbos. I revved the engine a got an awesome ass explosion out of the thing - missus came out to see what had happened!!! Reckon that one would have been good for some flamage:)
Ahh ya bast*rd , was counting the posts and you pipped me for top of page.
The reason I have taken so long is the 8 pages of you trying to con Niz into coming over and/or coming across.
Bad Paul:D
they are fellow SAU members not highly desirable , goodlooking Skyline loving sex objects.
* Ken excuses himself for another cold shower *
Cheers
I have a dream
Ken
Originally posted by Micko
I believ so Paul - I will find out.
As I said Micko , you could try Eddie Wong if Jerry is unavaliable.
Ring me for his number , I think I have it somewhere.
Cheers
Ken
Originally posted by GTS-t VSPEC
Micko, If Ken thinks it's AFM related, which sounds likely, have you traced the wiring back etc, how about an oscilloscope to view the signal?
See'ya:burnout:
Yea , was thinking that but have absolutely NFI where to start on that.
Thats why I suggested Eddie Wong cos thats what he uses.
Why pauly are you a sine wave expert
To me if a wire has more than one end , I'm buggered.lol
Cheers
Hopeless sparky
Ken
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
