  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Still think the popping and crackling on overun plus the fuel smeel is the AFM giving an incorrect signal.
It probably has to die more b4 it codes or the wiring going to it could be at fault.
Cheers
ken
Ken, I didn't see your name on Lauren, free game:p
Micko, Anything which will allow you to view the main sensors has got to be of benefit, sometimes a worn wire will cause noise on the signal which will cause this sort of strange behaviour.
See'ya:burnout:
Crackling - I'll give ya crackling...
When I got home I was listening to the idle whilst cooling down the turbos. I revved the engine a got an awesome ass explosion out of the thing - missus came out to see what had happened!!! Reckon that one would have been good for some flamage:)
Ahh ya bast*rd , was counting the posts and you pipped me for top of page.
The reason I have taken so long is the 8 pages of you trying to con Niz into coming over and/or coming across.
Bad Paul:D
they are fellow SAU members not highly desirable , goodlooking Skyline loving sex objects.
* Ken excuses himself for another cold shower *
Cheers
I have a dream
Ken
Originally posted by Micko
I believ so Paul - I will find out.
As I said Micko , you could try Eddie Wong if Jerry is unavaliable.
Ring me for his number , I think I have it somewhere.
Cheers
Ken
Originally posted by GTS-t VSPEC
Micko, If Ken thinks it's AFM related, which sounds likely, have you traced the wiring back etc, how about an oscilloscope to view the signal?
See'ya:burnout:
Yea , was thinking that but have absolutely NFI where to start on that.
Thats why I suggested Eddie Wong cos thats what he uses.
Why pauly are you a sine wave expert
To me if a wire has more than one end , I'm buggered.lol
Cheers
Hopeless sparky
Ken
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
