Originally posted by GTS-t VSPEC
If you do get offered then it might be kinda to commit them to a mental instituation:p
Have they found a cure for ugly yet Ken?
See'ya:burnout:
As i said b4 , I'm fat but can lose weight.
You will be ugly forever:bahaha:
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Most rev-head chicks ain't to special, so be careful who you invite to join us, j/k
Chicks don't like to waste money on cars, they prefer to waste it on clothes.
See'ya:burnout:
Wrong
ANY revhead chick is special cos when I was young there weren't ANY around.
They were ALL into clothes
* sob , sob *
Cheers
Ken
Tasmania - dont think so - someone show me a map please:)
The auto sparky that I went to in Joondalup had an awesome $14k diagnostic tool that plugged into the car & also had a hand held cro - misht get him to go for a drive with me. Only problem is I don't know what the signals shiould look like but i think the magic book says what output coltage ranges should come up.
BTW - you're right Ken, I am about to lose my self control. Had to restrain myslelf from putting on the steel caps & hammering a couple of panels this afternoon - Naomi told me to go and have a lie down before I got out of hand.
Ken,
When you were young the dinosaurs roamed the Earth.
See'ya:burnout:
Go to bed it's after midnight and you sure as hell need your beauty sleep
Cheers
Ken
ps , Nope , it was the ice age
my clutch is ghey. it slips above 5psi in 1st gear... grr.
so i lowered my boost.... down to like 2psi, daym, i almost forgot what it was like to drive a non-turbo. all this in an attempt to make my clutch live a little longer so i can save more fold.
come to think of it, how can a "bleeder" valve LOWER boost, if it is by definition an air "bleeder"... ho hummm...
Kym,
Sorry to hear your not feeling well. A bleeder can only drop boost to a minimum oof 0.5bar (stock boost), by fully closing it.
Sorry to hear about the clutch, you don't seem to catch a break with your car, but just think, by the time you've replaced some of these things the car will be stronger for it.
See'ya:burnout:
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
