  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
that barina would be alll over the place
13b rotary pretty powerful
barina= light, small girls hatchback!
crazy!!!!!!!!!!!!!!!1
maybe i cna transplant a rb26dett stroked out to 2.8
with the full jap catalogues chucked into it, into my sis's excel?
hehhe
adrian :)
hehehe nah
it's my sis's car!
she can pay for it!
i will just direct her
then i will drive it hehehe
crazy drift stylez!
adrian :)
of course make sure atessa4wd is switched off
for even more crazier drift stylez!
adrian :D
okay urgent news i just remembered to ask u all!
i did a burnout at my mates house right!
and i left two wheel marks on the road?
does this mean i got LSD?
i think it does?
coz i never done a burnout and held it like that before
and when i came back
my mates were like u left two skid marks
i was like whoa?
can sumone explain to me?
adrian :)
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
