  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kym,
It's not better, there is no real conversations, just idle banter.
Bully, You must be embarrassed by Psiker:p
See'ya:burnout:
No im very proud off both my sons they are wonderful -- im sure Psiker would buy a quality vehicle if he could but his situation at the moment precludes that -- i have been there and done that and understand that you cant have everything u want at once
bet your happy to get it back - becareful when you get it back - last time i got my car back from a long 3 week stint away i took it for a bit of a drive (hmm if you could call it that) got a little too excited going around a corner and spun it out - luckily noone was coming the other way and i didnt hit anything or anyone.
Hows the shirts going?
Originally posted by skyzerr33
will re open when forum rules are adhered to
other wise u have the mirc channel
Troy
What is this all about ??
I thought this was whoretown and was used for general chit chat and as Niz pointed out * to get to know people*.
The threads I believe have cleaned up and the W A ones certainly appear to stay on topic.
There appears to be a few members who believe that is not so and I don't know what they are referring to.
If it's this thread then simple , don't open it , stick to the sections that interest them .
Cheers
I'm confused but whats new
Ken
PS mirc is usually more mindless one line drivel than here and favours the fleet of fingers
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
