Originally posted by skyzerr33
thats right ken u keep chatting up the girl younger than your your own kids
Troy , I don't have kids . How do you think I can afford the cars ?:D
Besides , whats wrong with talking to people under 25.
people my age are usually boring with no interests apart from watching sport and TV
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah trust me dont have kids around cars - i picked the tinting off my parents brand new/used 4wd when i was little (and it was the first time they could afford something sorta nice) then i proceeded to paint their beige roof with my mars bar hahaha. I couldnt sit down for a week!!
old guys are cool - like the guys at welshpool pits - i get along with them sooo well - ive got to go and REALLY suck up to them soon - puppy dog eyes, short skirt the lot - gotta get them to pass my old heap of a ZX to send to QLD. The guy wants a roadworthy certificate.
yeah the welshpool guys are nice. My car failed after compliance and they were like "we;re so sorry but we just can't let it go" then I bought i back and there was still some stuff (the compliance guy stuffed up) and he said look just promise me you'll get it fixed. He was really nice! My friend is a supervisor there so that may have helped.,...
Originally posted by Nizmo
well if things dont change Troy after they've been thoroughly reminded of the proper ettiquette then everyone just ignore them. They get ignored, they get bored, they leave.
well that doesn't work just look at ken hes still here hehe
lightsabre fight on star wars
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
