Originally posted by Nizmo
haha just my dad - gotta take someone to pay the bill :P
Nah i dont get taken out to dinner anymore - nobody loves me *sniff* haha
Hmmm , 5 guys dive for niz's PM button .
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
geez guys im actually not the man eater i appear to be haha i am quite sweet - my dad mentioned tonight how i constantly used to give in to the ex <- Dad didnt like him much.
But i am as stubborn as all hell and like to get my own way - but i reckon the fairy could pull off bigger tantrums than me!
Heeeheeeeheeee
I knew if I persisted with the fairy bit it would catch on.
Cheers
Ken
Originally posted by GTS-t VSPEC
Hi Ken,
See, we managed to fix something without your help:p
See'ya:burnout:
What , so the 2 phonecalls don't count as assistance ?
Cheers
whats this , the RAC:D
Ken
Originally posted by skyzerr33
haha we can have a tantrum contest staring pwptfwbgaw, niz and ken
kylie can judge as she sees tantrums all day at work
Ok , I'm gonna have to ask
Whats the wbgaw on the end ??
Cheers
It's gonna be rude
Ken
Originally posted by Micko
Yeah sorry about that old chap - thanks for all your help again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again wise silent Ken...
Nah , just kidding.
It's all part of the lifetime after sales service warranty.lol
Cheers
Ken
Ken - you dirty man go get some tissues
Paul - bloody oath I like reassuring when I'm talking about an expensive piece of machinery... never can be too sure
don't worry micko, naomi prefers the real thing to the dildo u got her for xmas
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
