  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Shznt
WA is not a state, it is a juvenile center for delinquents who was abandoned by their mothers and fathers. As a result we pity you.... and that's enough effort from us as we are too busy running the damn country!!!!
oh what a brilliant job ur doing letting that little lap dog send troops to fight bushes illegal war
and surprise surprise who do they send in first the elite sas australia's best troops and where do they come from PERTH thats right we have the best troops
we will invade qld bwahaha
