  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha u cant win here so go to VIC where u know the target is easier haha.
hmmm looks like i will have to investigate on monday bully:
"so lauren how was the meals"
"dont know but the beer was good" hehehe
