  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
*Ken reliving past glories*:bahaha:
Swedish skid car? a Volvo?
See'ya:burnout:
Take a look in the garage at the next MC day and you will see what I mean.
Trust me , teaching the general population about skid control , recognition and recovery is not easy.
The amount of people who react about 2 secs behind the car is scarey:mad:
Cheers
Ken
Originally posted by bully
Ken i used the one at Puckapunyal in victoria I was A Navy driving istructor there -- i think we had the firsts set in the country
That would have been the ones with landrovers on them.
I think you got them thru NZ
Cheers
Ken
Bully,
Thanks for the lesson in old cars. You old guys are good for something.
See'ya:burnout:
ahh youth and stupidity ......
Goes hand in hand . Little one , listen for there is much to learn.....
Cheers
Ken
yer we also set them o up with some Falcons on them
we had Nissan Pulsar N14's on ours and moved to toyota Camrys ( V6 ).
Used to love doing the reverse flick into h/brake into reverse flick after the students had gone.
Any one who reckons you can't opposite lock a front wheel drive has NOT been in one of these things. Hehehehe
Cheers
Ken
Ken -- do you know Geoff Branch??
No but I believe a couple of guys came from the Army over there with skid car experience and are working for DTEC
John Willmot is one I think
Cheers
Ken
Cheers
Ken
i think i saw a video of that set up with the camrys once when we were look into contracting out driver training for the services
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
