Originally posted by GTS-t VSPEC
Bully,
I'm sure it is tough sometimes, like most jobs.
Ken,
Has Niz been talking about me again?
See'ya:burnout:
no , you have been doing all the talking .
Her and us are doing all the laughing:D
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Laugh all you will, but I don't hear Niz complaining * tightens gag on Niz's mouth*
See'ya:burnout:
if this was Joe posting he would have said
* gag ?? , stick your schlong in there. *
but it's not so I won't
Hehehe
Cheers
Ken
Ken,
You sound like your jealous, but Niz is old enough to be your grand-daughter:bahaha:
See'ya:burnout:
Mate the day you stop admiring is they day you die.
Besides , having pretty young things talking to or about you is always good for the ego.
* sucks in gut and preens hair *
* forgets to breathe and passes out *
Cheers
Ken
Ken,
Rules suck, it this true even in Sports Sedan class etc.
See'ya:burnout:
opening yes , material no.
Why , you gonna compete against Tony Ricciardello.lol
Cheers
Ken
Ken,
Even I have to suck my gut in these days, dread to think what I'll look like at your age:p
You don't have any old photo's of Steve Thomas do you, when he had long hair?
See'ya:burnout:
no but if I did it would be worth a lifetime of free dynos.
We ALL looked pretty wild back in those days
Cheers
Ken
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
