  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
EPOCH,
Yes, next to a brothel, but even I am not that desparate, that's money I could spend on mods:p
Ken,
What pads do you recommend? *speaking to GTRKEN*
See'ya:burnout:
best roadbased pad ( ie good cold bite , kind to discs , reasonable wear , no or little fade ) would have to be Pagid rs4-2's ( blue ones ).
I have not tried too many but the pagids are good for me.
Ferodo 2500 or 3000 are also supposed to work.
Ultimately you get exactly what you pay for.
price for pagids are bout $400 an end.
Cheers
Ken
If I buy one, then I want a fully modded one, prefer with roll cage etc. Sometime next year i hope.
See'ya:burnout:
Cage will not be legal over here and watch the mods. Depending on what you want to do ( wanners ,ses , mc) some of the mods may not be legal.
I can get them but suppose Danny or Ray will help you there.
Cheers
Ken
At $400 I think I'll stick with cheapies:p
See'ya:burnout:
ahh well , thats why a more dedicated person will beat you.
Motor racing is hell expensive at every level and there will always be someone who will commit to the best.
Wanners is 75% car , 25% driver . A bad driver can win in a good car but the opposite will never happen.
Cheers
Ken
Morning Troy,
Vibration can be due to a unblanced flywheel, or the fact that the harmonic balancer needs to be adjusted for the lightened flywheel.
Bunny hopping is usually due to the clutch's pucks gripping and then slipping.
See'ya:burnout:
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
