  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
paul and brett u can keep guessing
my plates are ordered and on there way
u'll never get it
Yoda
Wookie
Skywalker
Luke4Eva
Starwars
HansSolo
Lightsaber
It'll be something to do with Star Wars.
my mum makes the best pasties (yes she cooked for once *shock horror*) So we had yummy pasties tonight.
I make the best casoroles - proper beef n red wine ones not that packet shite! - they are so yummy in winter!
Sneeza
Haven't seen you post for at least..........hmm.
bout a 100 pages of this garbage.
Hows the car or is this something we don't ask.
BTW , I have come to the conclusion that Niz does very little and pwptf does NO work during the day.
Geez you two can whore !!:(
Takes me 1/2 hr each night just to catch up on this Days of our lives thread.
Cheers
Ken
Joe - its a database type program I think - like mulitmedia databases. I think. It stores everything in a database. Its like a softwarre suite (like MS office) that has a web builder and stuff. Don;t know what programs - its all web stuff. I assume it would support java
Joe - here you go
ColdFusion has its own page markup language, called ColdFusion Markup Language (CFML). CFML encompasses the Web's Hypertext Markup Language (HTML) and Extensible Markup Language (XML). A just-in-time (JIT) compiler turns the CFML into the pages that get served. Allaire emphasizes that their product set is open and "extensible". Applications can access databases using Microsoft's OLE DB, Open Database Connectivity (ODBC), or drivers that access Oracle and Sybase databases. ColdFusion can be coordinated with distributed applications that use Common Object Request Broker Architecture (CORBA) or Microsoft's Distributed Component Object Model (DCOM) to interact with other network applications.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
