Originally posted by Sneeza
I also remember that there was something that didn't add up from the old 4, 5, 6 films to what was in 1 and 2....but can't remember.... wait.... in number 4 obi wan met c3po for the first time but then in number 1 or 2 - he meets him there... it was something like that
SNEEZA !!:O
Cut it out , we had 10 pages of Starwars off the Stargeek a while ago.:(
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah its 7 demerits currently.... or no driving offenses in the last 4 years.... there are a couple of conditions
Ohh thats ok cos I'm a good boy now.
Can't say the same about my record 15years ago tho:rolleyes:
Cheers
Ken
my uncle died like that. Hit a flock of sheep on a track in leinster - he got flipped with the car - he wasn't wearing a seatbelt. His foot got stuck in the door so he was on the outside.It was like 2 days before someone came along. would not have been a pretty site
And seeing that sort of thing doesn't worry you ??
Cheers
Ken
Hmmm..
The stargeek must have gone to his starwars chronicles .
You must have given him a hard one.
Maybe he is watching the first three episodes again to confirm your theory.:(
The sad git:p
Cheers
Ken
No - when the adrenaline is going its amazing what you can deal with. I am in the SES and I've been on searches where we've been bascially told its a dead body we're looking for. If I can handle that - then... I should be ok. Its when you start thinking about what your seeing, smelling etc and instead of acting on it the way you've been trained - that's when you dry retch and stuff
hey how about being on the bus that some decides to commit suide with by jumping in front of it on the freeway then having his limp twisted body land next to your window at the back of the bus all white and see his eyes roll up in to his head as he chokes on his own blood!!!
well you are a definite minority cos if I saw or smelt a dead body I would prolly faint/ dry retch/ be sick / all of the above
Cheers
Ken
ahh sneeza
if u watch 1 and 2 obiwan doesn't actually meat 3PO. if your refering to anakin not recognising him or vice versa the favoured rumour is that 3PO has had a memory wipe and anakin/vader doesn't get to see hin in his gold cladding, as there are many 3PO driods.
and no i had to run a batch job on some backups
HEY !!
your supposed to be consulting your Stargeek library for the answer to Sneeza's question:D
Now go and do your homework you naughty boy or I will get Kyles to
You
Cheers
Ken
He probably won't do cos I know he likes a good
:O
Kyles told me last night :bahaha:
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
