Originally posted by Sneeza
I also remember that there was something that didn't add up from the old 4, 5, 6 films to what was in 1 and 2....but can't remember.... wait.... in number 4 obi wan met c3po for the first time but then in number 1 or 2 - he meets him there... it was something like that
SNEEZA !!:O
Cut it out , we had 10 pages of Starwars off the Stargeek a while ago.:(
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah its 7 demerits currently.... or no driving offenses in the last 4 years.... there are a couple of conditions
Ohh thats ok cos I'm a good boy now.
Can't say the same about my record 15years ago tho:rolleyes:
Cheers
Ken
my uncle died like that. Hit a flock of sheep on a track in leinster - he got flipped with the car - he wasn't wearing a seatbelt. His foot got stuck in the door so he was on the outside.It was like 2 days before someone came along. would not have been a pretty site
And seeing that sort of thing doesn't worry you ??
Cheers
Ken
Hmmm..
The stargeek must have gone to his starwars chronicles .
You must have given him a hard one.
Maybe he is watching the first three episodes again to confirm your theory.:(
The sad git:p
Cheers
Ken
No - when the adrenaline is going its amazing what you can deal with. I am in the SES and I've been on searches where we've been bascially told its a dead body we're looking for. If I can handle that - then... I should be ok. Its when you start thinking about what your seeing, smelling etc and instead of acting on it the way you've been trained - that's when you dry retch and stuff
hey how about being on the bus that some decides to commit suide with by jumping in front of it on the freeway then having his limp twisted body land next to your window at the back of the bus all white and see his eyes roll up in to his head as he chokes on his own blood!!!
well you are a definite minority cos if I saw or smelt a dead body I would prolly faint/ dry retch/ be sick / all of the above
Cheers
Ken
ahh sneeza
if u watch 1 and 2 obiwan doesn't actually meat 3PO. if your refering to anakin not recognising him or vice versa the favoured rumour is that 3PO has had a memory wipe and anakin/vader doesn't get to see hin in his gold cladding, as there are many 3PO driods.
and no i had to run a batch job on some backups
HEY !!
your supposed to be consulting your Stargeek library for the answer to Sneeza's question:D
Now go and do your homework you naughty boy or I will get Kyles to
You
Cheers
Ken
He probably won't do cos I know he likes a good
:O
Kyles told me last night :bahaha:
    • It seems to happen only when moving not stationary. It happens more frequently when reversing and turning steering wheel to the right. I MAY have found what the sound is and if it’s that I will feel so dumb since it did start happening around when I put 18” wheels. I attached the image of where there’s a scraping line to that plastic liner and the other side does not have that.
    • Is it a noise that if you turn the wheel, and hold it turned to the right, the screech continues? Or does it only occur while you're moving the steering wheel? Does it occur when stationary turning the steering wheel from centre to the right?
    • I want to also note I did lift the tire and checked for any play to see if it was a bad tie rod. It doesn't move at all.
    • Any insight will help find the issue. When I do a sharp turn to the right I hear a screeching sound coming from the front. It only happens turning Right and not Left. Steering fluid seems okay. Not sure what this part is(picture) but one side seemed "wetter" than the other. All bushing from a quick look did not seem damaged. I'll do a better look but wanted to ask here in case it helps me troubleshoot faster.
    • Nah, they'll do it without a receipt, tell em roughly when it was, that it was cash, youll likely only get store credit, but that gets you some dollars towards the newer better shovel, or other item you need/want later.   Still take it back and have a crack at returning it.
