  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Wally llama Ken and his words of wisdom!
Private PM between sneeza and me.
So nyeh , nyeh:D :bahaha:
Oh shit , He's BAAAAAAACK
pwpt60secf.
And I see micko the slow reader is on. Gotta love 56K modem. It will take him all night to catch up . hehehe
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
Were you just having a go at my staying power? I don't need pills to stand at attention:p
See'ya:burnout:
I may be a slow starter but once I get going.......
Cheers
Ken
Yeah, Micko is the voyeur, he likes to read, but not join in. I haven't bothered to read back yet, seeing as I wasn't here not much would have happened:p
See'ya:burnout:
Thats what you think.
Rooms booked , camera crew and backup is ready , just waiting for the Main Event.
Cheers
Not johnny Farnham again
Ken
I hope you didn't buy too much film:p
Your giving the hand a real workout?
Niz,
Just thinking of you makes the blood rush from my head:p
See'ya:burnout:
Yea niz , god never gave man enough to fill both.
Cheers
Ken
RSI ?? wouldn't waste it on the hand.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
    • Looks better than dusted paint, and also looks better than the old OEM one, much happy
