  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
definately have to get this suspension fixed asap - dragging a motorbike on the way to work - doing pretty well considering he was 10X lighter than me then i hit a rough patch of road and with a squeel of the wheels hehe i decided the car couldnt hack the surface grrrrr. was having so much fun!
car giving you dramas Niz....
took the rex out to High Wycombe last night to vist me best mate... first time ive drive the car in a week.....
forgot how many dips**ts are on the roads in the crappy cars who want to drag you....
1st - P Plater in Mirage with his tart girlfriend pulls up at the lights and starts reving the crap out of it.. i though he was joking so didnt bother.. lights turn green and this fool drops the clutch and burns off at his blistering pace (hahhahah).... i causely drive along next set of lights same story.... except he looks over laughs and starts reving againing thinking that he just blew me away hell embaras me again...
fark that 5K clutch drop and see ya.... idiot. comes flying up ..."what you got in that thing???"stupid tool...
Dan
Since i bought my private plates I haven't been able to find a single drag except for people in lancers or 1945 model pulsars!??
I pull up next to a V8 who has been thrashing it between cars the whole time just give it a bit of a rev to let him know I am there and he didn't run....
I really want to give that lotus a run Dan that i was tellin you about.... I might not win but it would be a gun run... might come close though :-) once ITC is on (Finnaly!!) will be pulling 290 so should be a good run!
2nd - tool in V8 falcon driving up my ar*e, i pull over to let him through, and flys past. Get to lights and Trev and Pete in the V8 are getting ready to roll.... tools
what is it that every time you take the car out sh*tboxes want to race you.
Dan
hahaha nice work dan!
i see the wrx is still providing u some entertainment
dun worry
on the way to work
some gangsta tried draggin me in his try to be evo lancer
i was like okay then HOWABOUT NO!
hehehee
****sticks
Sup Niz, how r ya? you know the prices u put up before from wilkinsons and wa suspension were they for springs and shocks
or for full coilovers? adrian :D
Me had some fun last night, practicing lauches against my mate's wrx... jeezus those things grip!
Needless to say I don't! I was trying to practice lauches to see if I'd be any good on Sat.. every single time was huge and I mean huge wheelspin... he even beat me at one stage - imagine that! a wrx beating the mighty power of the skylor?!?! Luckily I got traction sometime into second and showed him skylor power! yea!
hehehe.. sorry - early morning boredem setting in at work already!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
