  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I went to the Cas the other week and I went out to that smoking terrace with my friend. - these ladies were in there and they wouldn't move cause they were watching that no one stole their pokie. When i walked out I pretended to sit there hahaha But then I realised i valued my life
cant say my car has been christened either - two doors are killers and leather seats arent much better haha. You only live once - wherever the urge calls haha.
ah bedroom man only are we paul haha
casinos are sooo sad thats why i dont go! old men trying to hit on you - old girls that have their own "butt groove" on the pokies chair. just a very sad place to be. not a gambleing person either waste of money the odd lotto ticket is a far as i go.
but paul you've got the better suspension haha! Mine just couldnt cope with it! Ok as long as theres no stains i have a practically perfect interior i would like to keep it that way hahaha
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
