  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
what am i suppose to send out the bat signal or something paul - dont have your number hahaha
Ahhh the * batters eyelids * signal.
btw he posted his number about 20 pages back
I think it's 1800 loser. Hehehe
Cheers
Ken
always wondered what a uni degree got u - now i know :)
Me ??
Uni degree.
I don't think so , barely got leaving or 5th year or whatever you call it these days.:P
Cheers
Ken
what u expect me to go hunting for it haha no it has to be given to me for me to use it not given to another girl then me just scam it - thats called stalking :P
Well give us all your number and I will give you pwptf ( for what it's worth )
Ohh well the phone sex bill will be cheap cos it will be quick
Cheers
Ken
Originally posted by GTS-t VSPEC
Niz the number is 0422 971 915 *just for you*
Ken,
1800 LOSER is your number:p
See'ya:burnout:
Ooooooohhhh
Thats a good comeback.
Loser , no you are , no you are !:P
btw Page ownage AGAIN , again.
Boy , I'm on a roll:burnout:
Cheers
Ken
Originally posted by gtrken
Better hope she starts quick or you will be all out of juice in 60 secs
Cheers
Ken
I was gonna stay out of the fray - but this one almost split my sides - good work Ken.
OK - if I'm not mistaken, it's ttpoupt (take the piss out of paul time)...
Can I play?
Ken,
I think she was having a go at me:bahaha:
See'ya:burnout:
yea , giving it to Sneeza first.
Niz will think she is not loved , worshipped , honoured , put on a pedestal , given romantic dinners to , chocolates and flowers , long weekends away.....
*scuse me , need a tissue *
Cheers
Ken
well 0403 33* *** - ive already been told by one of the eastern states guys that not a good thing to post my number up here but since most people know my number plate, where i live and where i work i think my nubmer is probably safer haha.
so any funny sms's anyone gets feel free to pass along haha or work time is always a good time to sms and amuse me.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
