  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
yea , giving it to Sneeza first.
Niz will think she is not loved , worshipped , honoured , put on a pedestal , given romantic dinners to , chocolates and flowers , long weekends away.....
*scuse me , need a tissue *
Cheers
Ken
who said u dont understand women?!!
Originally posted by Nizmo
well  - ive already been told by one of the eastern states guys that not a good thing to post my number up here but since most people know my number plate, where i live and where i work i think my nubmer is probably safer haha.
so any funny sms's anyone gets feel free to pass along haha or work time is always a good time to sms and amuse me.
Errr niz I was only kidding and I think it would be wise to edit that number out.
It's OK for some silly blokes like us to give it out but in your case , I think thats not wise.
Cheers
concerned parent type look
Ken
Cheers
Ken
Good advice Ken - prolly too late cos paul's written it down now anyhow.
Think you might have to edit it from your quote also:rolleyes:
im someone that i screen my calls too haha theres this one guy that i dated when i was 15 and i bumped into him at the shops a few months ago anyway he wanted to catch up which was fine then his girlfriend dumped him and he became all clingy too me and he's weirdo now so i just let my voicebank get it along with a lot of other people i dont want to talk too!
Most guys in town must be gay then if they have your number and your sitting on this forum talking to 4 weirdos and an old bloke.
Thing is you would have given your number to them cos you know them.
This is the Skyline forum and we are all friendly but with just under 2500 members who know you are nineteen , blonde , single , female , 6' 1'' ...
* scuse me , another tissue *
back on topic
all it takes is one weirdo ( pwptf for one ) to cause you a lot of anguish and number change.
Cheers
Ken
ps I was kidding about pwptf , he is one of the gay ones anyway
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
