  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I try not to include whore in my job description, incase they want me to do sexual favours:p
See'ya:burnout:
nah i no longer work for car dealerships - dont get asked for those favours ianymore haha
anyway whats this faster than niz business haha - like im a challenge to beat ! hehe :D
but i cant prove your wrong paul your too quick! Maybe if we can take the engine out and you push your car up the track then i may have a slight chance of winning haha tempted to throw in another macka joke but i think ive given him enough already haha.
yummy yummy sandwhich!
saw so many 180's going to get lunch today - invasion i tell ya!
hmmm what other bits of uninteresting time wasting bullcrap can i share with you........ give me a couple of moments i will think of something. :D
troy who u order ur ebc from?
howdy dudes,
how r ya all today? the weathers gettin a tad dodgy eh? come back summmmmmmmmmmmmmmmmmmmmmmmmmmmmmer
i am very very bored, no gym today either, feel like a extra fat slob!
adrian :D
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
