Originally posted by gtrken
But a set of 2530's and a power FC will change all that.:)
He getting 2530's now?
Right, that's it...
*Naomi - looks like my turbos are stuffed, damn that GTRKen, he sold me a dud, I'll have to get some new ones, OK?...No response, oh well*
I might be there on Sunday, with any luck:cool:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Right, that's it...
just drive the pulsar hehe
Originally posted by GTS-t VSPEC
Ken,
I think the R32 looks a little skinny, needs a wide body kit:p
*rubs salt into the wound*
See'ya:burnout:
all the better to slip through the air with , no drag for the drags . Hehehe
Cheers
Ken
