  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken aka gtrken aka Jaffo aka Silent Ken aka Old Bastard aka ...
Lots of names, same wanker:p
See'ya:burnout:
ahh pwpt60secf
what can I say??
At my age , well...
at your age there is something wrong with you:D
Cheers
ken
Originally posted by skyzerr33
he thinks his mums hot u gotta be worried man
abit incestutious
gee troy , your getting better
Almost spelt incestou... , incestchoe.... , incestu...
yea that word right.
Cheers
Ken
Originally posted by Micko
Bit rich coming from you Mr Big turbo, etc, etc 500hp man with the 2 minute noodle & a 1 minute fuse
Nice one Micko, knew you had a good retort hidden somewhere.
I'll be beating your GTR one day *prays to God*
See'ya:burnout:
Originally posted by 33Spec2
I dont crap in cars its ok! thats wat toilets r 4!:)
thats what the last navigator said before we crashed .
Had to steamclean the seats and that was on my side:D
Cheers
Ken
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
