  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yes i love canadian club - baileys is ok in small doses - it gets too milky after a while! I used to love sambuca but thats until i drank too much one night ...... hmmm black sambucca + cream carpet + new boyfriend never a good mix hahaha
Sambucca , is that the crap that tastes like aniseed ?
Cheers
Ken
Originally posted by gtrken
thats what they call you to your face.
You should see what pwpt60secf calls you when you go to bed .:P
Cheers
Ken
As long as the words Sex and goddess feature ken im happy :P
Originally posted by angel
Trying to drag my mind out of the gutter.
Why , when you come to whoretown at this time of night , that's where we are.
Bumping along in the gutter , trying to climb out , then pwpt60secf or Troy come on and it's straight down the sewer
cheers
Ken
yeah theres white, yellow, black and i think green (could be wrong) sambucca. But Black was the only one i like and yes it tastes like licorice - aniceedy. My friend gave me yellow for my 18th b'day but it was just after my little "mishap" and it's still in my room unopened - cant even think about it - yuk!!
Yes u seem to be into your karoke - should move to japan - crazy about it over there as well.
Ken i hope to one day get paul to bat for our team - haha but it takes baby steps! tch tch such a waste :P
Hmm yes , my last fling with that aniseed stuff ended up in a face plant of my mates backyard. That was a looooong time ago though.
Cheers
Ken
one day when i was a little 17 year old - had a crap day at work came home drank a whole small bottle of sambuca - was fine, intoxicated but fine. Attempted it one night again but on an empty stomach tho - hmmm not so fine! I really liked the taste til then - dont see what everyone sees wrong with it :P
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
