  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Adam, the training is on a skidpan with different 'courses' laid out with witches hats which are designed to teach you how to drive on roads that aren't straight as if they were (sort of anyway).
On the normal MC training days they have up to 20 drivers/cars over the 3 hours - the one we are looking at will mean we have 5 drivers over 3 hours.
Simple math tells me we will learn more.
I assume that was more along the lines of what you wanted to know?
If there is enough interest I will organise one of the regular training days cos they are great fun with a big group & if we did the morning session we could all go to the pub after for a good counter meal, beer & brag about our skills (& take the piss out of macka:))
That would cost us $55 each & last time we did it we had an absolute ball.
Will definately put you down as no2 on the bench.
You guys should come out & watch us anyway - I always come down to watch everyone else running at the drags.
Originally posted by skyzerr33
how much for a head gasket? stock
installed me thinks thats the deal
its not missing
but the water i put in is now a mecky brown and then a hiss (air escaping noise) when the car is running.
Got your message but I am not sms 'ing the answer.
Hissing noise , from where.
Cheers
ken
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
