  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
skyzerrrrrr your headgasket has probably gne because of the excessive blowby from the busted ringlands
alas roll it into the shed.
Headgasket  from nissan is about $100
Macka , you are making about as much sense and at least as many spelling errors as Joe !:P
Cheers
Ken
ken ur a whore and u love it!
I like my avatar  and thats all that matters!
A double quote , thats a first .
I am not a whore cos they do it for money.
I do it for free:D
Cheers
Ken
Originally posted by Pva_Glue
Anyone needs experienced camera man? :P
You ?? !!
you spend all your time in the shotgun seat going
OMFG , I'M GONNA DIE !! OMFG .
and gripping the packshit bar ( grab handle ).:P :bahaha:
Cheers
Ken
and when would my ringlands busted and caused the blowby?
when do i ever make sence
dammit i keep getting phone calls and all of a sudden im a page behind
You paying them for phone sex or they paying you?
Page ownage , 2 in a row but alas .. no bookend.
Thanks for nothing Macka:D
Cheers
ken
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
