  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
skyzerrrrrr your headgasket has probably gne because of the excessive blowby from the busted ringlands
alas roll it into the shed.
Headgasket  from nissan is about $100
Macka , you are making about as much sense and at least as many spelling errors as Joe !:P
Cheers
Ken
ken ur a whore and u love it!
I like my avatar  and thats all that matters!
A double quote , thats a first .
I am not a whore cos they do it for money.
I do it for free:D
Cheers
Ken
Originally posted by Pva_Glue
Anyone needs experienced camera man? :P
You ?? !!
you spend all your time in the shotgun seat going
OMFG , I'M GONNA DIE !! OMFG .
and gripping the packshit bar ( grab handle ).:P :bahaha:
Cheers
Ken
and when would my ringlands busted and caused the blowby?
when do i ever make sence
dammit i keep getting phone calls and all of a sudden im a page behind
You paying them for phone sex or they paying you?
Page ownage , 2 in a row but alas .. no bookend.
Thanks for nothing Macka:D
Cheers
ken
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
