Originally posted by GTS-t VSPEC
His mind improved? I don't think so, he keeps asking for my advice, an obvious sign of insanity:p
See'ya:burnout:
yea , he asked your advice and then rung me for a closer to the truth answer.
Cheers
Ken:D :P :shake:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Fremantle is the start of the cruise, although we are meeting with NOR people further up:D
See'ya:burnout:
there is a south of the river ??
Wouldn't know these days , don't go there:D
Cheers
Ken
Ken,
Did we end up at the same conclusion, headgasket?
Troy,
Your a cheat and everyone knows it:p
See'ya:burnout:
no u didn't
and your the only one that thinks i'm a cheat
whoring is whoring use all the dirty tricks u know to win hehe
Ken,
Troy,
See'ya:burnout:
No , buggered Rad cap atm until Troy can pinpoint more things.
Very hard to diagnose over the phone with someone who can fix a computer but can barely find a dipstick:D lol
Cheers
Ken
Rad cap? Suppose, but would you like to wager on it:D
See'ya:burnout:
nothing
just out od interest how much is metal 2mm headgasket?
i've figure about $700 all up to replace the stock one with a stock one if thats the case.
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
