  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah welshpool rd hehe then kewdale rd - im constantly a black blur going up and down those :D
car was quite well behaved today actually slightly sluggish but the idle shudder was nearly non existant.
Sorry to stink everyone out with my toxic plastic bag smell haha some of u thought it was your own car haha
yes its been pointed out that my exhaust is really low - whole friggin car is really low haha. I cant fit under there to get the remainder of the bag off so its just going to have to burn baby burn!
hmmph vengaboys - joe wouldnt even got there if had that cd would of kicked him out on the side of the road and driven off :D haha
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
