  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
oh its a cul de sac paul and its got a nice long run up into it with a nice little corner thats fun to go around as fast as you can - in fact the whole suburb is my own personal obstacle coarse even the brakes get a good work out when a kid decides to run across the road at the wrong time.
just dont understand why they dont go play in the friggin park! but then again if i had that many kids i would tell a few to go play on the road too haha
thats horrible niz!
id tell them all 2 go play on the road and the ones that survive get 2 stay - survival of the fittest! :P
hmmmm two door car and kids do not mix! it'll be a friggin long time before anyone see me taking the sub out just so i can fit a nappy, bottle, pusher in the boot. Ive seen what kids do to cars and its not pretty :P
Originally posted by GTS-t VSPEC
Niz,
I don't think Micko would wants you shaving his balls, he doesn't have much to play with to begin with:p
Macka,
No phone in couch. That's what roo bars are for:D
See'ya:burnout:
huh? i didnt say anything about shaving anyones balls - eek! bad mental pictures!
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
