  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Psiker,
You drive an Excel, of course you have not idea:p
Russel, Chill dude, you've missed the boat:D
See'ya:burnout:
did u know its a proven statistic that driving around in a excel looses u 2% of general knowledge per 500km's
no really
yes dumb i know
nite
Psiker
