  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i think my body clock is screwed at the moment all i want to do is sleep all day during work and at night ive got too much energy and dont want to sleep - weird. Had a really bad dream last night :D
Originally posted by GTS-t VSPEC
Joe,
You must have too much energy, go find a girl to take it out on:D
See'ya:burnout:
Originally posted by skyzerr33
yeah joe tanya is calling your name
I havn't seen her since Friday night...:)
damm... I am getting frust#$%#$^$%&$%^
I better seek help of Mrs.Plamer and her five dauthers :D
hahah ive always been like that! defineatly not a mornin person! can neva get out of bed but i cant sleep at nite which is great 4 weekends coz i can go all nite but not weekdays wen im sleepin through tafe! its coz i hav low blood pressure which means not enough iron
yeah you take it under your matts etc flooring and into the boot onto your battery but i think u should get the proper fuses first because without them you could blow something or it could catch a light. Then again i drove aroundin my ZX for 6 months with stuff hooked up to battery and was fine :D wouldnt risk it tho.
Neons eh? my bday im getting MC motorsport paid for..... was suppose to be getting mums radar detector - oh well.
Originally posted by 33Spec2
Ok ok you caught me! i have a blue neon under each seat (xmas presents) anyway ive always had them connected 2 cigarette lighter but its butt ugly connected 2 lighter and apparently it is sposed 2 b easy to hook up without goin through lighter but i cant figure it out!
if you want to get rid of the wires...
pull out he center console, including gear socks and where lighter is located... use bit of soldering iron and make little switch for dickies smithdies bam you have instant night club!!!! :D it sould only take couple of hours!
or do it properly run the wire through the side panel where is says Skyline under the door!
cheers
Joe
hey joe dont complain your getting more than me boy!
My mates got low iron - shes always complaining how tired she is - drives me insane - stop ya whinging bitch haha specially when your trying to party on a holiday and she wants to sit in front of the TV all day.
Troy dreams dont usually affect me - im one of these people that realises its a dream and snaps out of it but this one was pretty vivid and i think it dragged up something but to the back of my mind - for that reason i wont share :D Just hope i sleep better tonight!
yeah all my wires are run under the skyline panel - bloody still poking out everywhere friggin strathfield! Both my ZX and lines stereo wires keep peeping out from below the glove box - even blue tack wont hold them in place and they look god damn ugly!
hi all - me back from cheap ass pasta night at the moon.. yummy! should do a meet there one night..
33spec - u'll wanna hook it up with a fused wire to the battery and a switch on the dash so you can turn them off right? You should be able to take power from behind the deck as long as the neons don't draw too much, which will let you throw a switch somewhere in the dash.. easy as pie.. :D
Joe - waaaaay too much info bud... hehe...
Niz - what dates are you doing the MC day? Are you using your own car?
ahh it was that one of paul being your long lost twin sister
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
