Ohh btw , might have to ask a favour and do a wheel swap for a coupla weeks.
Take your pic , the 17's on the racer or the 18's on the ricer.
Need for compliance but has to go to Sydney.
Reason Niz is there is only 1 place left in Aust that has a spare R32 GTR plate and that's Sydney Compliance.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
joe i was bought up religous too til i was about 10 - um worse than christian - pretty embarrassed about it actually but i was brought up a J.W. but neither my parents or i have anything to do withthe religon anymore - although my grandparents try and bible bash me so its simple i just dont visit them anymore.
Originally posted by Nizmo
im fussy with my men too ken - i wouldnt still be single if i wasnt :) the rabbits were just good friends but they were good quality too rabbits without fleas :D
Bwahahaha
Funniest post I have seen so far tonight.
Cheers
Ken
Originally posted by Micko
You asking me about the wheels Ken?
I'll go back & check out the pics - but the one you just posted looks great (once the stickers are gone of course).
Ken - how many r's you had now?
Note the link , GTR6
Plus the Targa one which as we know , alas , is no more.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
