  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
well shes got a whip, handcuffs and a silk scarfe will that do?
Ohh I am SOOOOO there!!:D
Troy , you got somewhere I can send a 1.3mb vid for pwpt60secf.
Kym's email wont take it either.
Cheers
Ken
Originally posted by adam 32
you sent me like 50?! even the one of joe with the black g-string bent over the bonnet of your car, dont know what inspired that one
I hope that was photoshopped .
Please say it was photoshopped:D
Ewww , too much for the imagination.
Cheers
Ken
Originally posted by Pva_Glue
I can I want Please!
[email protected]
cheers KEN!
Joe , normal email stops at 1.1 mb.
Sides , I would have to clear it with Paul.
Lets just say the speed was err...... yea.
Cheers
Ken
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
