  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cam - its my wedding. These are the boxes with the chocolate things in them that you give as gifts to the guests.
We are going to drink and tie, drink and tie hahah me and bridesmaid have made a pact to drink beer every day this week. Yesterday we drank at rosies, today..... we'll find somewhere
