  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yep - they have to do that cos their boss tells them to. All will be AOK, so don't worry.
Funny but most of the customers want us to do it that wat - then they don't have to go back to the bank to put the money into their account - can't please everyone I suppose:rolleyes:
Originally posted by skyzerr33
micko pops in again for a goodnight call
hey micko can tandi refund money via an eftpos machine?
cause kylie got the wrong modem to start with went back got the right one which was $20 cheap and they refunded via the eftpos machine
didn't think u could do that
Yes they can refund via eftpos.
Kyles wasn't happy when I told her that computer I sold you for her already had a modem.
btw , decided you only owe me $200 and we will call it square.
cheers
Ken
hey ken which cars u got in this ralley theres something on drive tv about it now
There not mine , I just work at the shop there based at and help run the team.
R Herridge wrx
S dirou wrx
B Markovic wrx
G furness wrx
A smits ( if you can't guess then you are a total moron )
Cheers
Ken:D
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
