  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yep - they have to do that cos their boss tells them to. All will be AOK, so don't worry.
Funny but most of the customers want us to do it that wat - then they don't have to go back to the bank to put the money into their account - can't please everyone I suppose:rolleyes:
Originally posted by skyzerr33
micko pops in again for a goodnight call
hey micko can tandi refund money via an eftpos machine?
cause kylie got the wrong modem to start with went back got the right one which was $20 cheap and they refunded via the eftpos machine
didn't think u could do that
Yes they can refund via eftpos.
Kyles wasn't happy when I told her that computer I sold you for her already had a modem.
btw , decided you only owe me $200 and we will call it square.
cheers
Ken
hey ken which cars u got in this ralley theres something on drive tv about it now
There not mine , I just work at the shop there based at and help run the team.
R Herridge wrx
S dirou wrx
B Markovic wrx
G furness wrx
A smits ( if you can't guess then you are a total moron )
Cheers
Ken:D
